[postgis-devel] [PostGIS] #593: [raster] Add a ST_BandIsNoData function
PostGIS trac at osgeo.org
Fri Jan 14 05:57:44 PST 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 > - What should we do in case of offline bands? We could check the values
 using GDAL.[[BR]]
 This job should be done by raster2pgsql.py
 > - Correct me if I'm wrong, but we don't need the isnodata flag to be
 stored in WKB string
 Yes. It must be persistent. The code should look exactly like the code for
 hasnodata.
 Most of the work has to be done in raster2pgsql.py (and every set pixel
 functions).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/593#comment:6>
