[postgis-devel] [PostGIS] #773: regress failure in topology
PostGIS trac at osgeo.org
Sun Jan 16 01:21:02 PST 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by robe):
 Strk,
 Actually maybe this is invalid.  I think my GEOS build is dated 12/22 just
 before you made the change to shared path.  You think that would cause the
 difference?  I'll recompile GEOS and see if that fixes the issue and then
 close this out if it does. On my other mingw box when I tested last week
 all was good and I think I have a newer GEOS version on that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/773#comment:6>
