[postgis-devel] Not able to do make comments_install
aperi2007 aperi2007 at gmail.com
Sun Jan 16 03:36:10 PST 2011
On debian lenny 32 bit ,
I'm try-ing to compile and install last version postgis 200 from trunk.
I notice don't work the
(never try it before)
the problem is that I work under an account other then root.
But switch to root to do the
make install
even the make comments_install must executed with the root account,
but, I don't know why, using the root user I cannot see the
comments-install file
otherwise it is visible from the other user.
there is some setting I don' t know to do work the
make comments-install with the root user ?
thx,
Andrea.
