[postgis-devel] [PostGIS] #772: [topology] ValidateTopology takes way too much time
PostGIS trac at osgeo.org
Sun Jan 16 10:47:14 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 So, removing the check for overlapping faces and face-in-face makes the
 run complete in  7 minutes against a reduced topology which wasn't
 completing in over 6 hours.
 This other, smaller topology has these characteristics:
 - 4896 nodes
 - 5687 edges (total 87222 points)postgis make collection
 - 1724 faces
 Interesting enough, the validation reports lots of coincident nodes and an
 edge/edge crossing, which makes me wonder if it makes sense at all to try
 at analize faces if there are errors with edges (since faces are defined
 _by_ edges...)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/772#comment:2>
