[postgis-devel] [PostGIS] #782: Topology: st_newedgessplit(..) don't seem work as expected
PostGIS trac at osgeo.org
Mon Jan 17 14:35:56 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 I try this code:
 select
 topology.AddEdge('schema_topo',ST_GeomFromEWKT('SRID=3003;LINESTRING(1 4,
 4 4, 5 5)'));
 select topology.ST_NewedgesSplit('schema_topo',1,
 ST_GeomFromEWKT('SRID=3003;LINESTRING(4 7, 4 4)'));
 Having this error:
 >[Errore] Righe script: 1-35 ------------------------
  ERROR: SQL/MM Spatial exception - point not on edge
  Riga: 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/782>
