[postgis-devel] [PostGIS] #781: topology: wrong result when add an edge intersecting a face.
PostGIS trac at osgeo.org
Mon Jan 17 14:42:44 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Not sure I got it right (it's late here).
 Are you basically adding an edge that splits a face but goes from a node
 to another ?
 That's a case I haven't indeed considered for AddEdge.
 The use case that drove AddEdge/AddFace was one by which you wouldn't have
 registered
 any face at the time of edge addition.
 A balance should be found between validity and speed. Checking everything
 would have
 a big impact on performance. This is pretty much like forcing an
 ST_IsValid check on geometries, only more expensive...
 Note that AddEdge never attempts at defining faces. Even adding a closed
 edge produces
 no face (altought it theoretically should).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/781#comment:3>
