[postgis-devel] [PostGIS] #785: Topology functions should be tolerance aware
PostGIS trac at osgeo.org
Mon Jan 17 20:55:51 PST 2011
 Reporter:  robe         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
 In testing functions like ST_NewEdgesSplit, I am reminded that the
 topology functions don't seem to consider the tolerance that was put in
 for a topology.
 For example I created a topology with tolerance of 0.5 meters.
 e.g. if I had an edge like this
 ST_GeomFromText('LINESTRING(227575.8 893917.2,227591.9 893900.4)', 26986);
 And tried to split at
 ST_GeomFromText('POINT(227578.909683258 893913.955113122)', 26986)
 I get an error its not on the line yet if I take the distance between the
 2 --
 SELECT ST_Distance(ST_GeomFromText('POINT(227578.909683258
 893913.955113122)', 26986), ST_GeomFromText('LINESTRING(227575.8
 893917.2,227591.9 893900.4)', 26986));
 I get 0.
 Wondering if we should replace our use of ST_Within when comparing a
 linetring to a point (and ST_Intersects) with ST_DWithin(,,tolerance)
 Or are there changes in GEOS that will make this work?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/785>
