[postgis-devel] Topology: is ST_ModEdgesSplit spelled right?
Paragon Corporation lr at pcorp.us
Mon Jan 17 21:04:58 PST 2011
Strk,
I was googling and the only document I could find on the web that covers the
SQL MM topology functions is this one.
http://www.wiscorp.com/H2-2005-108r2-Topo-Routine-Details.pdf
Which I have been using for contrast and compare.
I notice they use this spelling:
ST_ModEdgeSplit
But ours is spelled ST_ModeEdgesSplit
In theory I can see why this one doesn't have an S but t ST_NewEdgesSplit
does
Because in the Mod case the original edge is not destroyed but changed so
you are getting one new edge where as second you destroy the existing  and
create two new.
So which spelling is right?
Thanks,
Regina
