[postgis-devel] [PostGIS] #781: topology: wrong result when add an edge intersecting a face.
PostGIS trac at osgeo.org
Tue Jan 18 05:57:34 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Correct, you shouldn't use AddEdge if faces are defined.
 Maybe we could have AddEdge check this prerequisite. Should be a quick
 check.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/781#comment:5>
