[postgis-devel] [PostGIS] #797: ST_RemoveIsoNode does not throw an exception when passed a non-existent node
PostGIS trac at osgeo.org
Fri Jan 21 00:21:58 PST 2011
node
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  low       |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by aperi2007):
 A non-existent node is surely removed. :)
 This result is compliant with the description of the ST_RemoveIsoNode.
 And the node is isolated because as say the 2.c rules of draft there isn't
 any edge having it has start_node or end_node.
 So I think the result is correct.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/797#comment:1>
