[postgis-devel] [PostGIS] #802: AsGML: use posList with attribute rather than coordinates tag
PostGIS trac at osgeo.org
Sat Jan 22 06:00:14 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 I tested with the xsd of GML 3.1.1.
 Under a TopoCurve
 is mandatory a directedEdge.
 under the directedEdfge the only choice is Edge
 with the two directedNode.
 under the Edge because the choice is "curveProperties"
 under a curveProperties in a TopoCurve the only choice availables are:
 CompositeCurve, OrientableCurve, Curve and LineString
 so the logical choice is "LineString".
 There isn't the option of "LineStringSegment".
 That instead is good for the MultiCurve tag od type simplefeature (not for
 the topology "TopoCurve").
Ticket URL: <http://trac.osgeo.org/postgis/ticket/802#comment:2>
