[postgis-devel] [PostGIS] #812: topology: xlink prefix customizable
PostGIS trac at osgeo.org
Thu Jan 27 10:02:22 PST 2011
 Reporter:  aperi2007    |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by aperi2007):
 >So, if you xlink:href="1" you don't know if it's Edge, Node or Face with
 identifier
 >"1".
 The important is the unique property for anchor in the list of GML tags.
 So if you use the number 1 for node is sufficient don't use it for edge.
 Instead you know what is it,
 because in a directededge in the xlink_href the anchor can be only link an
 edge. It never could be a node or other.
 Also an anchor in a directedNode is necessary a node.
 >Beside, we are not referencing faces at all, since ISO faces and GML
 faces have a >different meaning so we don't have an identifier for the GML
 faces (by all effects >being rings rather than surfaces)
 However i guess would be better to have an ID even for faces.
 Because this allow a more simple identification of a single face in a more
 complex TopoSurface (in the GML output).
 I guess the three component of TopoSurface and TopoCurve:
 Face, Edge and Node would be identificable with an ID unique.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/812#comment:2>
