[postgis-devel] [PostGIS] #812: topology: xlink prefix customizable
PostGIS trac at osgeo.org
Thu Jan 27 11:42:53 PST 2011
 Reporter:  aperi2007    |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by strk):
 The identifiers we are using are really the identifiers in the db
 (edge_id, node_id).
 They are not made up by the AsGML routine.
 Would it be ok, for your use case, to prepend the user-defined string to
 what
 we have now ? For instance: if you specify "rt-250-" as the prefix, you
 get:
 "rt-250-E1" for Edge id 1 and "rt-250-N1" for Node id 1.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/812#comment:3>
