[postgis-devel] [PostGIS] #815: topology: topology.asgml(topo, visitedTable) give wrong results
PostGIS trac at osgeo.org
Sun Jan 30 01:56:04 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by strk):
 The caricamento.test table must disagree with you. Check it doesn't have a
 row with element_type = 2 and element_id = 1.
 The function assumes the visitedTable contains correct informations, and
 only queries and appends records to it. It's up to you to clean the table
 up
 when you're finished writing a set of TopoGeometries.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/815#comment:1>
