[postgis-devel] [PostGIS] #809: errors building the documentation
PostGIS trac at osgeo.org
Mon Jan 31 15:11:55 PST 2011
 Reporter:  strk     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  docs     |
Comment(by robe):
 Strk,
 I'm not sure how to solve this.  I don't get errors (at least not building
 comments which is all I build) and hudson doesn't seem to building the
 full doc.  the xrefs are all in the autogenerated postgis_aggs_mm.xml so
 it seems your build is maybe not building that file?
 Have you always had this problem?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/809#comment:2>
