[postgis-devel] [PostGIS] #1064: [raster] transform regress failing on 8.4 windows build
PostGIS trac at osgeo.org
Fri Jul 1 02:06:17 PDT 2011
 Reporter:  robe            |       Owner:  dustymugs
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by mcayland):
 Yes - if you can't load the postgis-2.0.dll library when loading the
 PostGIS functions into a database on Windows then that generally means the
 loader can't find a dependent DLL somewhere. Check that the GEOS, PROJ and
 libxml DLLs are somewhere not too far away or maybe even use MS's
 depends.exe to see what else the DLL depends upon.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1064#comment:10>
