[postgis-devel] [PostGIS] #1080: cunit is crashing on test_ShpDumerDestroy()
PostGIS trac at osgeo.org
Fri Jul 1 02:38:21 PDT 2011
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  blocker        |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by mcayland):
 I was unable to reproduce the crash locally, but I noticed that the config
 initialiser wasn't being called which would have left some pointers
 intialised with random data. Hence a call to ShpDumperDestroy() would try
 to free random pointer values which could cause a crash.
 Could you try a checkout >= r7533 and let me know if that fixes the issue?
 Incidentally we should probably fix the regression tests so that "make
 check" runs even if --with-gui is not specified during configure.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1080#comment:2>
