[postgis-devel] geocoder rev 7531
Paragon Corporation lr at pcorp.us
Fri Jul 1 14:27:53 PDT 2011
Are you still having issue?
Last time this happened to me on Linux, it was because I had some dangling
windows breaks in there that Linux evidentially did not appreciate.
I thought I got rid of all of those though.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
maplabs at light42.com
Sent: Friday, July 01, 2011 3:26 AM
To: postgis-devel at postgis.refractions.net
Subject: Re: [postgis-devel] geocoder rev 7531
> Brian,
> Does your log show anything?  I just revised to force Unix line breaks
> and also got rid of the  CREATE index call at the end which might have
> been causing problems.
2011-06-30 21:04:06 PDT|[unknown]|4e0d4736.5557 LOG:  connection
received: host=[local]
2011-06-30 21:04:06 PDT|geocoder|4e0d4736.5557 LOG:  connection
authorized: user=dbb database=geocoder
2011-06-30 21:04:06 PDT|geocoder|4e0d4736.5557 LOG:  statement: ALTER TABLE
state_lookup ADD COLUMN statefp char(2); ..
2011-06-30 21:13:03 PDT|[unknown]|4e0d494f.559d LOG:  connection
2011-06-30 21:13:03 PDT|dbb|4e0d494f.559d LOG:  connection authorized:
user=dbb database=dbb
2011-06-30 21:13:21 PDT|[unknown]|4e0d4961.55a0 LOG:  connection
2011-06-30 21:13:21 PDT|geocoder|4e0d4961.55a0 LOG:  connection
2011-06-30 21:13:32 PDT|geocoder|4e0d4961.55a0 LOG:  duration: 77.251 ms
statement: select postgis_full_version();
  nine minutes later I checked postgis_version() HTOP showed Idle in
Transaction, iir
> Unfortunately not near a Linux machine at moment so can't test.
> You can also remark out the line that reruns the tiger_loader.sql ..
> I haven't changed that in a while.
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
