[postgis-devel] [PostGIS] #1091: shp2pgsql gui wrong use of create spatial index
PostGIS trac at osgeo.org
Fri Jul 1 16:07:06 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 NO,
 is a new database created just today using the postgis-200 r7518
 experimental for windows.
 It work unchecking the "create spatial index".
 After, I see the same error in a my script where I have the same sintax
 create index... using gist("geom" gist_geometry_ops)
 but it was easy resolved removing the "gist_geometry_ops" string.
 Replying to [comment:3 robe]:
 > Andrea,
 > Are you using this on a new PostGIS 2.0 database or an older one or a
 1.5 one?
 > Hmm perhaps our loader no longer works with PostGIS 1.5.  That would be
 a big bummer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1091#comment:5>
