[postgis-devel] [PostGIS] #1090: regress test for ticket 183 fails (runding issue) (was: NOTICE: No points in input array)
PostGIS trac at osgeo.org
Sat Jul 2 01:44:29 PDT 2011
 Reporter:  bracket  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by strk):
 It is a rounding issue. Should be fixed in trunk. Can you confirm ?
 Which version of postgis are you running, btw ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1090#comment:1>
