[postgis-devel] [PostGIS] #1094: Fix broken curved regress tests
PostGIS trac at osgeo.org
Sat Jul 2 02:05:40 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 As a result of the switch to typmod as default behavior of
 AddGeometryColumn -- most of the curved support regress tests are failing.
 Paul can you take care of it.  Not sure what types these should be.
 For example this:
 CREATE TABLE public.circularstring (id INTEGER, description VARCHAR);
 SELECT AddGeometryColumn('public', 'circularstring', 'the_geom_2d', -1,
 'CIRCULARSTRING', 2);
 Now generates a statement:
 ALTER TABLE public.circularstring ADD COLUMN the_geom_2d
 geometry(CircularString, -1);
 Which gives error:
 {{{ ERROR:  Invalid geometry type modifier: circularstring }}}
 Not sure what it should be
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1094>
