[postgis-devel] [PostGIS] #1100: QuantumGIS no like pretty names
PostGIS trac at osgeo.org
Mon Jul 4 04:36:02 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Looking at qgis source code it also appears to be using 'geometrytype',
 which is likely gone in 2.0 isn't it ?
 The code is in src/providers/postgres/qgspostgresprovider.cpp
 Tickets for qgis should be filed here:
 http://hub.qgis.org/projects/quantum-gis
 It should use the same authentication means as this trac, so you should
 already have an account.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1100#comment:1>
