[postgis-devel] [PostGIS] #1023: topology regress failures related to GSERIALIZED: copytopology and
PostGIS trac at osgeo.org
Mon Jul 4 05:39:39 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 For CopyTopology regress test the offending query for the 8.4 case is:
 SELECT * FROM "CITY_data_UP_down".node EXCEPT
 SELECT * FROM "city_data".node;
 It actually fails for me too on 8.4.8 (succeeds in 8.4.3).
 It is probably related to btree index for geometry. Did its semantic
 change ?
 It used to be bounding box equality.
 Interesting enough it only fails for points, not for edges (which also
 have geometries involved).
 My failure case is on 32bit GNU/Linux and returns all of the 22 nodes from
 the query. In your case a single row is returned.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1023#comment:1>
