[postgis-devel] [PostGIS] #1023: btree equality broken for geometries w/out a cached bounding box (topology regress failures related to GSERIALIZED) (was: topology regress failures related to GSERIALIZED: copytopology and)
PostGIS trac at osgeo.org
Mon Jul 4 06:25:10 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by strk):
  * owner:  strk => pramsey
  * component:  topology => postgis
Comment:
 Found the problem:
 pglwgeom_getbox2d_p is expected to _compute_ the bounding box when no
 cached.
 In the non-gserialized flavor it does so (getbox2d_p in lwgeom_api.c)
 but in the gserialized flavor it doesn't (gserialized_get_box_p in
 g_serialized.c)
 The pglwgeom_getbox2d_p function is NOT documented to require computation,
 but I do know it (eh...).
 So:
  1. Document behavior
  2. Fix it for GSERIALIZED
 I'd like to hear from Paul about this first though, in case he has other
 clients relying on gserialized_get_gbox_p NOT computing a missing box.
 What I could do meanwhile is providing a regression test for this bug,
 which is _unrelated_ to topologies.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1023#comment:7>
