[postgis-devel] [PostGIS] #1104: lwgeom_homogenize does a shallow copy
PostGIS trac at osgeo.org
Mon Jul 4 06:55:54 PDT 2011
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Ok, I checked, lwcollection_homogenize uses lwgeom_clone, which in turn
 doesn't copy POINTARRAY memory (lwgeom_clone_deep would do that).
 Then I guess this can't be called a bug on itself, but a general need to
 cleanup the memory management framework. For now I fixed the test to use
 lwgeom_release which supposedly does a shallow free (but still fails to
 drop some memory...)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1104#comment:1>
