[postgis-devel] [PostGIS] #1102: Memory leaks in liblwgeom ?
PostGIS trac at osgeo.org
Mon Jul 4 12:58:11 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I belive the culprit here is lwgeom_clone taking no effort to properly set
 the referenced PTARRAY readonly flags, so if you clone an LWGEOM with
 fully-owned PTARRAY you'd end up with two versions pointing to the same
 PTARRAY and both marked as owning it (lw*_clone uses memcpy)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1102#comment:2>
