[postgis-devel] [PostGIS] #1114: [raster] ST_Resample
PostGIS trac at osgeo.org
Wed Jul 6 15:30:36 PDT 2011
 Reporter:  dustymugs       |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 With the use of GDAL's warp API, a full set of different functions is
 needed to provide end-user functions.  Therefore, the following function
 underlies all the other functions:
 _ST_Resample(
         rast raster,
         srid integer DEFAULT NULL,
         scalex double precision DEFAULT 0,
         scaley double precision DEFAULT 0,
         upperleftx double precision DEFAULT NULL,
         upperlefty double precision DEFAULT NULL,
         skewx double precision DEFAULT NULL,
         skewy double precision DEFAULT NULL,
         algorithm text DEFAULT 'NearestNeighbour',
         maxerr double precision DEFAULT 0.125
 ) -> raster
 User-facing functions will provide needed validation before passing
 parameters to the above function.
 As can be seen above, there is a "srid" parameter.  The expectation is
 that ST_Transform will be refactored to call _ST_Resample.
 The most comprehensive user function using _ST_Resample is:
 ST_Resample(
         rast raster,
 ) -> raster
 Parameters passed to ST_Resample will be validated to ensure that at least
 one of the srid, scale, upperleft and skew parameters are provided.
   returns the resampled raster
   srid: the SRID of the projection to use when reprojecting the raster
   scalex: the resampled raster's scale in the X axis. default is 0
 indicating that the user isn't specifying the resampled raster's scale
   scaley: the resampled raster's scale in the Y axis. default is 0
   upperleftx: the X component of the corner of the upper-left pixel of the
 resampled raster.  default is NULL indicating that the user isn't
 realigning the raster
   upperlefty: the Y component of the corner of the upper-left pixel of the
   skewx: the X component of the resampled raster's skew.  default is NULL
 indicating that the skew of the original raster will be applied to the the
 resampled raster
   skewy: the Y component of the resampled raster's skew.  default is NULL
 resampled raster
   algorithm: the resampling algorithm to use when resampling the raster.
 default is '!NearestNeighbour'. possible algorithms are:
 NearestNeighbour (default.  fastest performance but worst interpolation)
 NearestNeighbor (for those wanting to use the American spelling)
 Bilinear
 Cubic
 CubicSpline
 Lanczos
   maxerr: the threshold for transformation approximation by the resampling
 algorithm (in pixel units). default is 0.125, which is the same value used
 in GDAL gdalwarp utility. if set to zero, no approximation takes place.
 The other variant of ST_Resample is:
 ST_Resample(
         rast raster,
         ref raster,
 ) -> raster
   ref: the reference raster whose SRID, scale, upperleft coordinate and
 skew will be applied to the "rast" raster
 Additional functions will be documented in following entries for this
 ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1114>
