[postgis-devel] [PostGIS] #1111: Add matching status to geocode output
PostGIS trac at osgeo.org
Fri Jul 8 01:30:11 PDT 2011
 Reporter:  mikepease       |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
Comment(by robe):
 That's a good idea.  Was also thinking about having some configurable
 rating object you can pass in to denote the weights you want to use for
 each.  Though it would make things a bit verbose.  Possibly a lookup table
 of rating options and you just pass in a code to denote which you want to
 use.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1111#comment:1>
