[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Mon Jul 11 01:03:26 PDT 2011
 Reporter:  pramsey  |       Owner:  mcayland
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.4.3
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by realityexists):
 * cc: realityexists (added)
Comment:
 I'm also getting this error on PostGIS 1.5.2 on Windows, installed from
 the installer using Application Stack builder.
 SELECT Transform(ST_GeomFromEWKT('SRID=4267;POINT(-79.867611 9.3553472)'),
 4326)
 '''ERROR:  transform: couldn't project point (-79.8676 9.35535 0): failed
 to load NAD27-83 correction file (-38)
 However, this succeeds:
 SELECT Transform(Transform(ST_GeomFromEWKT('SRID=4267;POINT(-79.867611
 9.3553472)'), 3395), 4326)
 PostGIS full version: "POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel.
 4.6.1, 21 August 2008" LIBXML="2.7.6" USE_STATS"
 PostgreSQL version 9.0.4 on Windows, 32-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:25>
