[postgis-devel] [PostGIS] #1136: ST_distance_sphere producing unexpected results
PostGIS trac at osgeo.org
Wed Jul 20 14:17:31 PDT 2011
 Reporter:  darkpanda  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 As discussed here: http://postgis.refractions.net/pipermail/postgis-
 devel/2011-July/014460.html
 I was just messing around with the latest PostGIS 2.0 trunk and was
 running a unit test suite I have and noticed that ST_distance_sphere
 is returning some strange results. Here's the query I was running:
 SELECT ST_distance_sphere('POLYGON((-5 -5,-5 5,5 5,5 -5,-5 -5))', 'POINT(1
 1)');
 Which results in 444712.466496141 in the current trunk.
 postgis_full_version() says:
 POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
 2009" LIBXML="2.7.8" USE_STATS
 Whereas in PostGIS 1.5.3 I see a result of 0. postgis_full_version():
 POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
 Both PostGIS installs are on the same PostgreSQL 9.0.4 server.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1136>
