[postgis-devel] [PostGIS] #969: [raster] Inconsistent order of named args in ST_MapAlgebra
PostGIS trac at osgeo.org
Thu Jul 21 12:12:23 PDT 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  reopened
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Changes (by pracine):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I still get a problem with:
 SELECT ST_Mapalgebra(ST_TestRaster(0, 0, 1), 'rast + 280'::text,
 '16BUI'::text)
 which according to the doc should map to the third variant:
 raster ST_MapAlgebra(raster rast, text expression, text pixeltype)
 I get:
 LINE 1: SELECT ST_Mapalgebra(ST_TestRaster(0, 0, 1), 'rast + 280'::t...
 HINT:  Could not choose a best candidate function. You might need to add
 explicit type casts.
 I'm (still) on PostgreSQL 8.4.1...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/969#comment:10>
