[postgis-devel] [PostGIS] #1140: loader/PointZ test failing on my windows 9.0/9.1
PostGIS trac at osgeo.org
Fri Jul 22 05:17:52 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 I also tried on a different windows box running 8.4 - created a new db
 with local c
 CREATE DATABASE test
   WITH OWNER = postgres
        ENCODING = 'UTF8'
        TABLESPACE = pg_default
        LC_COLLATE = 'C'
        LC_CTYPE = 'C'
        CONNECTION LIMIT = -1;
 Ran my little test:
 SELECT * FROM (values ('01'),(' 03')) AS f ORDER BY 1;
 Output:
  column1
   03
  01
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1140#comment:6>
