[postgis-devel] [PostGIS] #1140: loader/PointZ test failing on my windows 9.0/9.1
trac at osgeo.org
Fri Jul 22 05:48:51 PDT 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by ads):
Well, after further testing it looks like your sorting is right and my
previous posting is misleading - and the test case seems to have a minor
problem:[[BR]]
The only LC_* setting is LC_MESSAGES on top of the file.[[BR]]
LC_COLLATE is never set and therefore depends on whatever the database is
using by default.[[BR]]
[[BR]]
In addition, I can't create a database with LC_COLLATE='C' - unless I use
template0 as template.[[BR]]
[[BR]]
So the tests are only run with C locale, if you have set OS and database
locale this way.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1140#comment:8>
