[postgis-devel] [PostGIS] #1141: [raster] ST_AsRaster
PostGIS trac at osgeo.org
Fri Jul 22 10:59:38 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Correct.  None of the ST_AsRaster version above provide parameters for
 both upperleft and grid.  Only the underlying _ST_AsRaster function has
 parameters for upperleft and grid.
 If someone were to bypass the functions above and use _ST_AsRaster or the
 underlying RASTER_asRaster function directly and provide values for
 upperleft and grid, the upperleft values would take priority as that is
 explicit rather than the computation required for a grid value.  Granted,
 by bypassing the user-facing functions, a user would be expected to
 responsible for whatever happens.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1141#comment:3>
