[postgis-devel] [PostGIS] #540: [wktraster] gdal2wktraster.py -l
John Thakkar thakkar at nexgenwireless.com
Mon Jul 25 16:01:31 PDT 2011
I am having same problem as described by this ticket.  Although, this ticket
is nowhere to be found.
When creating rasters with -l option,I get python errors as described below.
Any help would be appreciated.
#540: [wktraster] gdal2wktraster.py -l option is broken
Reporter:  pracine    |       Owner:  mloskot
     Type:  defect     |      Status:  new
 Priority:  high       |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  trunk
 Keywords:             |
If I try:
gdal2wktraster.py -r C:\Temp\test01.bmp -t testmultiimage -s 9102707 -k
200x200 -l 2 > C:\Temp\testmulti5.sql
I get:
   File "c:\postgres\bin\gdal2wktraster.py", line 1015, in <module>
     main()
   File "c:\postgres\bin\gdal2wktraster.py", line 976, in main
     wkblify_raster(opts, filename, i)
   File "c:\postgres\bin\gdal2wktraster.py", line 921, in wkblify_raster
     summary = wkblify_raster_level(options, ds, options.overview_level,
band_range, infile, i)
   File "c:\postgres\bin\gdal2wktraster.py", line 888, in
     hexwkb += wkblify_band(options, band, level, xoff, yoff,
read_block_size, block_size, infile, b)
   File "c:\postgres\bin\gdal2wktraster.py", line 796, in wkblify_band
     out_pixels[row] = out_line
ValueError: shape mismatch: objects cannot be broadcast to a single shape
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110725/470a95ad/attachment.html>
