[postgis-devel] [PostGIS] #1144: ST_MakeLine agregation error in order
PostGIS trac at osgeo.org
Wed Jul 27 05:59:06 PDT 2011
 Reporter:  arturbac  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  1.5.X
 Keywords:            |
Comment(by robe):
 Arturbac,
 I fear this is not really a bug.  The example in the docs usually works,
 but there is nothing in the ANSI-SQL specs that guarantees the order of
 the sub query is preserved so on occasion the planner may choose not to
 respect the order. I've just never noticed it in PostgreSQL changing the
 order.
 If you are running PostgreSQL 9.0+, the guaranteed way is to use the new
 ORDER BY clause within the aggregation.  I've updated the svn manual to
 reflect the new way. Sadly it won't work unless you are using 9.0+ (the
 postgis version doesn't matter)
 http://www.postgis.org/documentation/manual-svn/ST_MakeLine.html
 Give that a try and see if that works better
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1144#comment:1>
