[postgis-devel] make check question
Bryce L Nordgren bnordgren at gmail.com
Wed Jul 27 07:42:27 PDT 2011
On Wed, Jul 27, 2011 at 5:17 AM, Paragon Corporation <lr at pcorp.us> wrote:
> The reason why you don’t have to install first before doing a make check is
> that the regress version installs a version of postgis where the libdir is
> pointing at your regress folder .so/dll , and not the one in the normal bin
> folder of your PostgreSQL install.
> I forget, but I think this is the same case for the rppostgis.so/dll.****
So if I understand you correctly, the situation is:
1] Postgresql server installed on the same machine which is performing the
make check.
2] Postgresql server running prior to running "make check".
3] "make check" changes the library search path of the postgresql server at
run time in order to insert it's own "custom" libs.
Do I need to run make check using the same (OS) user who is running the
postgresql server, or can any (OS) user with access to the machine insert
their own libraries into my running server?
Thanks!
Bryce
> I’m on windows and compile using mingW so not sure how others do it, but I
> have 3 versions of PostgreSQL I test with  that I launch with a batch script
> on different ports prior to doing any compile make check.  So my compile
> script compiles for each, and then tests against the port I have for that
> version of PostgreSQL****
> By setting the PGPORT, PGUSER environment variables.****
> So my compile / make check / install script has these lines****
> export PGPORT=5434****
> export PG_VER=84****
> export PGUSER=postgres****
> And I change those for each version I compile against to get the right
> include paths etc.****
> The other VER variables are other ones I have defined to point at different
> versions of GDAL, XML, GEOS etc as needed****
> ./configure --prefix=/c/projects/pg/pg${PG_VER}
> --with-gdalconfig=/c/projects/gdal/rel-${GDAL_VER}/bin/gdal-config
> --with-xml2config=/c/projects/libxml/libxml2-${XML_VER}release/bin/xml2-config
> --with-pgconfig=/c/projects/pg/pg${PG_VER}/bin/pg_config
> --with-geosconfig=/c/projects/geos/rel-${GEOS_VER}/bin/geos-config
> --with-projdir=/c/projects/proj/rel-4.6.1 --with-gui --with-raster
> --with-topology****
> I think the process is essentially the same under Linux as it is in MingW
> so the above approach should work for you.****
> Hope that helps,****
> ****Regina********
> *From:* postgis-devel-bounces at postgis.refractions.net [mailto:
> postgis-devel-bounces at postgis.refractions.net] *On Behalf Of *Bryce L
> Nordgren
> *Sent:* Tuesday, July 26, 2011 10:49 PM
> *To:* **PostGIS Development Discussion**
> *Subject:* [postgis-devel] make check question****
> The attached file is the output from "make check" (after applying my patch
> on #1050). The CUnit tests appear to all run successfully. Then there's
> another phase where something tries to connect to a running server. This
> fails, of course, as there is no running server on my system (and if there
> were, it wouldn't be the modified version).
> When I first saw this, I took this to be an indication that you never run
> "make check" until the software is installed, the database cluster is
> initialized, and everything is happy. But I was corrected into the belief
> that "make check" should be run before "make install". But it's still trying
> to connect to a server which isn't there. So is there a trick? If the build
> system is supposed to be managing a "faux install" for testing purposes, is
> there something in the error messages which indicates what's going wrong?
> How isolated is the build directory from the system directories? (I'm
> running this as a regular user.)
> And of course, postgis is just an extension to the postgresql server, it
> doesn't contain the server code itself. How are you supposed to run the
> tests?
> Bryce****
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110727/6c1753fa/attachment.html>
