[postgis-devel] make check question
maplabs at light42.com maplabs at light42.com
Wed Jul 27 10:56:59 PDT 2011
I just re-built and tried   make check
I got the following:
---- Making check in liblwgeom
make[1]: Entering directory `/home/shared/srcs_xps/postgis_trunk/liblwgeom'
make -C cunit check
make[2]: Entering directory
`/home/shared/srcs_xps/postgis_trunk/liblwgeom/cunit'
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_algorithm.o
cu_algorithm.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_print.o cu_print.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_misc.o cu_misc.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_ptarray.o cu_ptarray.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_geodetic.o cu_geodetic.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_measures.o cu_measures.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_libgeom.o cu_libgeom.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_surface.o cu_surface.c
cu_surface.c:244: warning: ‘check_tgeom’ defined but not used
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_homogenize.o
cu_homogenize.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_wkt.o cu_out_wkt.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_wkb.o cu_out_wkb.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_gml.o cu_out_gml.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_kml.o cu_out_kml.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_geojson.o
cu_out_geojson.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_svg.o cu_out_svg.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_out_x3d.o cu_out_x3d.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_in_wkb.o cu_in_wkb.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_in_wkt.o cu_in_wkt.c
gcc -g -O2  -Wall -Wmissing-prototypes -I.. -c -o cu_tester.o cu_tester.c
cu_tester.c: In function ‘lwgeom_init_allocators’:
cu_tester.c:226: error: expected expression before ‘<<’ token
cu_tester.c:233: error: expected expression before ‘==’ token
cu_tester.c:239: error: expected expression before ‘>>’ token
make[2]: *** [cu_tester.o] Error 1
make[2]: Leaving directory
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/shared/srcs_xps/postgis_trunk/liblwgeom'
make: *** [check] Error 1
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=10.10
DISTRIB_CODENAME=maverick
DISTRIB_DESCRIPTION="Ubuntu 10.10"
Linux xps-420 2.6.38-02063802-generic #201103281246 SMP Mon Mar 28
12:50:24 UTC 2011 x86_64 GNU/Linux
