[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Thu Jul 28 14:42:38 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by bnordgren):
 Updated patch adopts strategy three on #1133 (create a new static library
 with common code which is Postgresql-aware.) This library is called
 libcommon. It lives beside `postgis`, `raster`, and `liblwgeom`. Patch is
 a delta from r7683.
 All cunit tests pass.
 All regression tests pass, except for "loader/Latin1" with some complaint
 about something being too long. I assume this is unrelated to anything I
 did, as it also fails in my other build tree from this svn revision.
 The patchfile itself looks funky to me, as it appears to be applying diffs
 to files after they have been moved. This may be a result of `svn mv`ing
 files to the libcommon directory, altering them, and then doing an svn
 diff. In any case, to preserve the commit history, you probably want to
 `svn mv` the relevant .h and .c files from `postgis/` to `libcommon/`
 before applying the patch.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1053#comment:2>
