[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Fri Jul 29 09:27:46 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by bnordgren):
 Added another version of the patch
 (attachment:lwgeom_transform_export.patch) generated via `svn export` and
 `diff`. First patch was made via `svn diff`, which exhibits strange
 behavior when describing a source tree with moved files. You may use
 either, but moving the file with the "patch" will cause the revision
 history to disappear.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1053#comment:3>
