[postgis-devel] [PostGIS] #1149: PostGIS crashes server when transforming martian data
PostGIS trac at osgeo.org
Sun Jul 31 10:15:12 PDT 2011
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:  windows  |
 This is described in:
 http://postgis.refractions.net/pipermail/postgis-
 users/2011-July/030413.html
 when converting data from:
 http://spatialreference.org/ref/iau2000/49900/
 To:
 http://spatialreference.org/ref/iau2000/49910/
 I have confirmed this to be an issue on Windows (my platform is Windows 7,
 64-bit running PostGIS 2.0 32-bit on 9.1 beta 3).
 "POSTGIS="2.0.0SVN" GEOS="3.3.1dev-CAPI-1.7.1" PROJ="Rel. 4.6.1, 21 August
 2008" LIBXML="2.7.8" USE_STATS"
 and shows in logs
 LOG:  server process (PID 2608) was terminated by exception 0xC0000005
 The person who posted this is running 8.4 on windows XP with the below but
 had also tried it with PostGIS 1.5 (same proj)
 This could be just an issue with windows or the older proj we compile our
 windows binaries with.
 Our next try will be to recompile using proj 4.7 to see if we exhibit the
 same error and if not just bite the bullet and switch PostGIS 2.0 to use
 4.7 for windows builds.  Which we were planning to do anyway after some
 more testing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1149>
