[postgis-devel] In-place upgrade to 2.0
Paragon Corporation lr at pcorp.us
Thu Jun 2 06:50:01 PDT 2011
Hmm wouldn't that require an update of all geometries in tables which could
be really really slow for large spatial databases?  Though I guess it would
be preferable to restore for large databases
With mostly non-spatial data.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, June 01, 2011 8:01 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] In-place upgrade to 2.0
Well, it was only going to be a temporary thing...
In its place I'm now considering a one-time-only function we could run that
would naively read 'geometry' assuming it is serialized_form and spit it
back out as gserialized. So an in-place upgrade script could go (a) is this
a 1.5 database? (b) ok, find all the tables (c) run this function on them
(d) upgrade the rest of the functions.
The only limitation that approach places is that the in/out functions and
anything else bound to the actual CREATE TYPE statement would have to remain
the same from 1.5 to 2.0. So no renaming those particular C functions.
P.
On Tue, May 31, 2011 at 2:12 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> On 24/05/11 16:30, Paul Ramsey wrote:
>> yes, my scheme was going to be to two-step by first creating
>> GEOMETRY2, then altering all the columns to that (by maintaining an
>> lwgeom handler to do the cast from serialized_form to gserialized),
>> then creating GEOMETRY and altering all the columns to that. Which
>> would work fine for data-only databases, but installations with more
>> complex constructions (views, triggers) expecting 'geometry' input
>> arguments might balk if I alter their column types underneath them.
>> P.
> GEOMETRY2? That sounds very Oracle-esque... ;)
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
