[postgis-devel] [PostGIS] #934: [raster] ST_Histogram and ST_ApproxHistogram
PostGIS trac at osgeo.org
Tue Jun 7 05:37:10 PDT 2011
  Reporter:  dustymugs       |       Owner:  dustymugs
      Type:  enhancement     |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:  history
Comment(by robe):
 Bborie,
 Is there any particular reason (aside from summarystats can be used for
 full coverages and has no breakouts so more likely to exceed integer),
 that you decided to make
 summarystats count bigint -  http://www.postgis.org/documentation/manual-
 svn/summarystats.html
 and histogram count integer - http://www.postgis.org/documentation/manual-
 svn/histogram.html
 I would just assume make both bigint.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/934#comment:5>
