[postgis-devel] [PostGIS] #1006: Change the scope of postgis-stubs dependency in postgis-jdbc Maven pom to "provided".
trac at osgeo.org
Wed Jun 8 01:50:12 PDT 2011
"provided".
Reporter: cheidmann | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.3.X
Keywords: maven |
At the moment org.postgis:postgis-jdbc:1.3.3 includes org.postgis:postgis-
stubs:1.3.3 as compile-dependency:
postgis-jdbc-1.3.3.pom:
<dependency>
<groupId>org.postgis</groupId>
<artifactId>postgis-stubs</artifactId>
<version>1.3.3</version>
<scope>compile</scope>
</dependency>
The "compile" scope is incorrect here, it should be "provided". The
"compile" scope means "dependency is required to compile and also needed
in the run-time".
The "provided" means "dependency is required to compile but we are sure it
will be provided in runtime".
Having "compile" instead of "provided" effectively adds the "postgis-
stubs" JAR to the classpath of the application which is not correct and
leads to problems like explained here:
http://postgis.refractions.net/pipermail/postgis-
users/2005-March/007153.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1006>
