[postgis-devel] [PostGIS] #1008: Too many columns in select crashes pgsql2shp
PostGIS trac at osgeo.org
Wed Jun 8 11:43:32 PDT 2011
 Reporter:  joshjordan     |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:  pgsql2shp      |
Comment(by strk):
 The code uses a lot of 'strcat' where 'strncat' should be used instead.
 Also, the current limit should be raised for this case to be supported.
 #define MAX_QUERY_LEN   2048
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1008#comment:1>
