[postgis-devel] [PostGIS] #1005: [raster] Problem with ST_SummaryStats(text, text) results
trac at osgeo.org
Wed Jun 8 14:15:11 PDT 2011
Reporter: pracine | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Yes. It uses the same one-pass standard deviation calculation method that
is used for each individual tile. Your example above comes to the correct
value.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1005#comment:16>
