[postgis-devel] [PostGIS] #672: Valid WKT crashes postgis parser
PostGIS trac at osgeo.org
Fri Jun 10 04:41:29 PDT 2011
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 1.5.4
 Component:  postgis  |     Version:  trunk
Resolution:  wontfix  |    Keywords:
Old description:
> =# select * from
> st_dump('GEOMETRYCOLLECTION(geometrycollection(empty),geometrycollection(empty))');
> server closed the connection unexpectedly
>         This probably means the server terminated abnormally
>         before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
New description:
 =# select * from
Comment(by strk):
 Fine with me too, as long as the new parser doesn't crash I'm happy.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/672#comment:7>
