[postgis-devel] [PostGIS] #1015: [raster] segfault on make check
PostGIS trac at osgeo.org
Fri Jun 10 10:52:58 PDT 2011
  Reporter:  strk            |       Owner:  pracine
      Type:  defect          |      Status:  closed
  Priority:  critical        |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  duplicate       |    Keywords:
Comment(by dustymugs):
 Which revision of GDAL trunk are you using?  I'm using !r22520.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1015#comment:4>
