[postgis-devel] PostGIS proj default path change
Paragon Corporation lr at pcorp.us
Fri Jun 10 14:20:38 PDT 2011
Mark,
Your opinion would be appreciated in this matter and of course I guess all
PSC have to vote on it since it's a packaging change.
I was thinking about how you said proj libraries should be installed in a
versioned folder under
Postgis-2.0
    proj
For example
Right now we have
postgis
   proj
postgis-1.5
postgis-2.0.
Which was sort of nice since proj shift files are a bit hefty and it allowed
all installs to share the same proj file.
With proj 4.7 -- the naming now defaults to libproj-0.dll which would mean
we could have postgis-1.. Using a different proj from Postgis-2  branch (at
least for windows anyway)
But I wouldn't want them using the same proj files.  So if you want, we
could change the search location to what you asked for a long time ago
postgis-2.0
   proj
What do people think about that change.  That would also fix the gdal issue
of not having to register libprojso since it defaults to libproj-0.dll
anyway.
So for people who are not sure what I'm talking about, I'm proposing to
change this line
http://trac.osgeo.org/postgis/browser/trunk/postgis/lwgeom_transform.c#L602
To go in versioned postgis folder.
So change from
strncat(path, "/contrib/postgis/proj", MAXPGPATH - strlen(path) - 1);
To
strncat(path, "/contrib/postgis-whatever_psotgis_version/proj", MAXPGPATH -
strlen(path) - 1);
