[postgis-devel] [PostGIS] #1005: [raster] Problem with ST_SummaryStats(text, text) results
PostGIS trac at osgeo.org
Fri Jun 10 17:54:04 PDT 2011
 Reporter:  pracine         |       Owner:  dustymugs
     Type:  defect          |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 I would remove ST_Count as well. In the case mentioned by robe, it is very
 easy to do ST_Height() * ST_Width() instead. The only remaining interest
 for ST_Count() is that is tells you of many pixel have a true value and in
 this case we are already at the lower level of granularity.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1005#comment:22>
